I am curious about this Z-wave hub mesh. Does it only work between Hubitat devices or could it work also between a Hubitat and the Blue by ADT security system?
I do not believe you can join that to a Hubitat via Zwave.
Edit: Hubmesh which is what is being talked about directly above is Hubitat hub to Hubitat hub. It cannot talk to other hubs or bridges.
Also, Hubitat’s “Hub Mesh” is Ethernet based between the Hubitat hubs. Each Hubitat hub can have its own Z-wave and/or Zigbee mesh networks, but hub-to-hub communications is via Ethernet.
