Since upgrading to the C7 hub (my C5 died), I have had problems with a rule that relies on checking to see if a Lutron dimmer switch was physically turned on.
The rule for the Virtual switch is:
Selected trigger Events:
Bathroom Light physical on
Select Actions to Run:
On: Bathroom Virtual Switch
Wait for event: Bathroom Light physical off --> timeout 1:00:00
Off: Bathroom Virtual Switch
I them have a rule for the lights that starts with IF (Bathroom Virtual Switch is off) Do stuff
What is now happening on the C7 hub, is that I will physically hit the switch to turn the lights on 100%, they will go on. I enter the room, and the lights will dim to the set level because the hub didn't seem to trigger the virtual switch, or there is a timing issue between the time it takes to set the virtual switch to on, vs running the rest of the rule?
