Is there an easy way to shut down a windows machine from within Hubitat (webcore, rule machine, other....)? I have a private network with only a mini pc, hubitat, and a Fire HD tablet connected.
EDIT : Gemini recommends this...
Option 1: The EventGhost + Hubitat Integration (Best for Hubitat)
If you want Hubitat (via webCoRE or Rule Machine) to control the Mini PC directly as a native switch, the community-built PC Controller (EventGhost) integration is the gold standard.
On your Windows 11 Mini PC:
Download and install EventGhost (a lightweight automation automation tool for Windows).
Install the Hubitat-to-EventGhost plugin. This opens a lightweight local listener on your PC that speaks directly to Hubitat over your LAN.
On Hubitat:
- Install the PC Controller app/driver package. It will generate a virtual device in Hubitat representing your Windows PC.
In webCoRE:
- You can now target that device directly in your pistons. Telling the device to turn "Off" or sending a custom event can trigger EventGhost on your Mini PC to execute a local Windows shutdown command instantly.
Gemini is correct that eventghost could do this. Is it still being actively developed?
Seems so...Gemini
Yes, EventGhost is still actively maintained and developed.
While it is a long-standing automation tool for Windows, the open-source project remains alive on GitHub (driven largely by community maintainers like kdschlosser and others). Updates and release candidates—such as the 0.5.0 release cycle—continue to roll out, bringing modern enhancements like improved 64-bit support (e.g., for VLC), bug fixes, and Python updates to keep it compatible with modern versions of Windows.
I guess it depends how Gemini defines active. The last release that’s in GitHub is from Feb 2025 and the forum appears to be dead.
That said, it probably still installs and does most (or all) of the things it used to do (though I haven’t messed around with it for several years).
If, for whatever reason, the Hubitat plugin that Gemini referenced doesn’t work for this use case, I would think that all you really need is to have eventghost listen for an http call sent by Rule Machine.
I made this a while back in claude. It works quite well...Uses a small groovy app on the hub and a windows persistent powershell script.
