Hi,
I'm new to the Hubitat home automation product and to the community so I'm lacking some knowledge in pairing devices. Can someone help me find the drivers compatible for the Sengled bulb E11-N14AW_2P?
I think the built in "Advanced ZigBee" bulbs drivers should do the trick. Just picked what type you have (RGB vs CT). After changing the driver, hit the configure button.
Ideally the hub will auto select the driver when pairing the bulb.
Thank you for responding. I was playing around with it and I found that it responded to the Sengled Element Classic bulb.
I appreciate the help!
Remember to always click configure when changing drivers.
