I didn’t see a post about the changes. Just curious if there is a list beyond 2.0.5.112.
No, there was one tiny bug fix in RM about global variables being set from a sensor -- that's all.
Thank you!
@bravenel I'm still getting the error below in 113 when I try to compare a sensor value to a GV set to decimal.
Update. It seems this error only occurs if the GV hasn't previously been set to a value.
Correct, that error comes from a variable still showing "not set". Fix found for the error, and will be in the next release. Thanks!
This has been fixed in the latest hot fix release.
