I wish to add a DewPoint calculation to my custom temperature / Humidity sensor driver.
In the past for "non-builtin" variables I've used "attribute" but reading through the documentation there is a capability "Variable"
For handling a measurement that is not a native capability (like temperature) which would be better to use?
I'm guessing the "attribute" is preferred as I've not been able to find any code that uses "capability variable". And I know the attribute can be accessed in RM.
If you implement capability "Variable"
, your attribute would have to be named variable
--that's the one specified by this capability. Further, you'd need a setVariable()
command, which is the means by which the variable
attribute is set. I can only assume this was created to handle Rule Machine global variable device connectors. Outside of that, it probably has little real-world use, and this itself was probably only there so apps could have a way to select these devices when the connector was created using this more generic capability instead of a specific "standard" capability (like switch or dimmer).
This is probably going to become even more obscure as more apps move towards the use of the new-ish hub variables feature and the ability to read, set, and subscribe to them directly without the need for a full-blown device (a gap that connectors--of any type--filled).
So, if you want a custom attribute named dewPoint
or whatnot, I'd suggest continuing to do that, by all means. The above wouldn't really make sense to me, especially as the capability also requires a command to set this value, whereas dew point is really just a calculated value--read-only, from the user's perspective. (If you want to stick to standard attributes only, i.e., those from capabilities, but you are already using temperature
for something else--likely actual temperature, as I assume your driver would--then you could consider creating a child "dew point" device with the temperature measurement capability and exposing the dew point via that. This is a standard attribute, so perhaps usable in more apps more easily. But some people don't like the clutter child devices arguably help create, and if you're already happy with how you're able to use the custom attribute, then...no need.)
Thank you. For those of us still learning your insight is very helpful
John
