Having a few weird issues with the built in webCoRE and was going to go ask over there. Where did it go??
Anyhow, I have a paused piston that is turning on and off my water heater recirculating pump. It's a freeze protection piston and it gets pause by our morning/shower time piston. Noticed that it turned off the pump while it was paused this morning. Any ideas? And any idea if HE's built in will be updated? I notice it has been over a year without updates. Been using webCoRE since StupidThings so I have a lot of pistons and it ""usually"" runs as intended.
I think Ian is more the IDE guy - web UI. I use staging so that's as current as it gets.
I haven't really looked at the build number for the built-in which is what I'm on now.
I was on the external one but HE advised that the fixes would propagate every monthish so I moved over to the HE version.
I pause pistons a lot depending on events but all of mine handle/terminate the devices that caused the reason for pausing.
I would presume that the scheduled task would still be in the HE queue but maybe WC does a cleanup on a pause.
A test piston should figure that out quickly. @nh.schottfam is probably the answer guy.
