What gives? Switch OFF method being reported
Hi
This should be impossible right!!
I switched the light off using the HE console, and the log showed this.
I can physically not get out of the chair & reach the light switch to also turn is off at the swicth for this to be correct!
Ideas on the cause anybody?
J
Depends on the device and driver being used, the generic zwave switch driver is the least accurate in this regard.
Which device and driver are you using?
I believe you're seeing the Hub send out the off command, followed 3.5 seconds later with the response from the device.
There's a large thread here on this topic and @JDRoberts #4 is probably a factor. The reply from the device gets altered along the way by older repeaters.
Mike, you're correct in the driver assessment - it is using the generic zwave switch. The device is [cough, cough] a GE 12722 Switch .
J
