What driver for this 4-1
I was given this device as a gift - Azoula Zigbee 4 in 1 Multi Sensor. Amazon shows it as 3.0 zigbee with HE support but I am unclear what driver might work with it.
I paired (not easily) but it came up as 'device'.
FWIW - the fingerprint:
fingerprint profileId:"0104", endpointId:"01", inClusters:"0000,0001,0003,0009,0400,0402,0405,0406,0500", outClusters:"0019", model:"HK-SENSOR-4IN1-A", manufacturer:"Sunricher", controllerType: "ZGB"
As a multi-sensor, if there’s no built-in driver for it, it would probably need a custom driver.
If there’s any overlap between Sunricher and Tuya, maybe a Tuya zigbee multi-sensor driver will work.
The Korean SiHAS 4-in-1 sensor has a fingerprint similar to this one. You can try the Tuya 4-in-1 driver - select the 'SiHAS USM-300Z 4-in-1' device profile :
Just as you suggested, the SIHAS selection in Tuya 4in1 driver worked great!
For anyone experimenting or using one of these units - The reset button (located inside the battery cover) does NOT start pairing mode. Pulling the batteries is the only way I could get device to pair. Pull out, count to 5, put back in - while hubitat is pairing mode... it connects about 3-5 seconds after the batterys are put in.
Values for temp, lux and humidity won't appear instantly. Wait a minute or two, and they will pop in. Refresh doesn't force them to appear.
The temperature is off on this by a few degrees. Strangely, when I was trying to get this going using a generic driver I could get a celsius reading which was very accurate, but once I switched to the Tuya SIHAS selection it showed in Farhenheit but was not as accurate. there may be a miscalculation in the conversion here.
The humidity was spot on. I have 2 other humidity detectors that I use for baseline, and it was dead center of those 2 values.
The Lux sensor - completely unsure if this is working well. Currently says Lux at 28. I think I need a decent lux sensor meter to baseline but checking with a phone app - I get a reading of 168 on the phone a few inches away.
The motion sensor is nicely sensitive - distance of 5-12 feet it was very fast, but the revert to inactive was very long - exactly 60 secs. I think 30 is more ideal personally.
I love this little unit! Has a really nice mount plate that is attractive. It uses 2 AAA batteries so I'm expecting longevity over coin batteries.
@kkossev My gratitude! Your driver(s) are super well done! Thank you. My kitchen thanks you and so do I.
