What driver for a lowes iris il03-1 smart plug?
As above, managed to wipe a device that i setup 4 years ago, oldtimers...
Does generic zigbee outlet work?
Cant figure out power monitoring, a driver that includes it.
It used to, now i cannot figure out what the driver was.
It does work, on/off with the generic driver.
Seems like someone made "Generic Zigbee Outlet" work in the past. Did you hit "Configure" after switching drivers?
I have to admit, this is now the only zigbee device on my c8.
Seems a little slow, i should wait it out, and move more ZB devices over from c4 to c8.
What in particular is slow? It could be a lot of things, either a general hub slowdown (unlikely if you don't have many apps or drivers on this hub yet), a range issue with just this one particular device, or some other oddity. Adding another device might help in the second case, but it's hard to say more without knowing more about your particular setup.
