What do you guys use to alert you of a power outage
I usually just look what time my clock stopped and compare it to my phone lol. There has to be a “real” way right?
I don't have anything that tells me of a power outage but I have set up a rule to send me a notification when my hub has started up.
This way I know that if it wasn't me who updated/rebooted my hub, something else has done it.
Power restoration or its done it itself for some reason.
Which rule is that? Thank you
Here is the rule I've defined.
I have put a condition in for the time as I reboot the hub at 02:30 in the morning and I don't want to send a notification for that.
Thank you
When my several UPS's start screaming... I know there's a power outage :slight_smile:
That's it. nothing complicated. If I'm not home, well I just don't know about it.
Same here, my ups yell. I’d bet there’s a small smart plug with a little built in battery that’ll report when power was lost and turned back on
I could connect the ups to my server and send a email, text, push, whatever. I just haven't bothered. If the power is out long enough for the batteries to die then I have far more things to worry about.
I have my UPS connected to an RPi running NUT. Then connect to Node-RED (and Hubitat) for alerting/shutdown control.
Could I use something like this to alert me if my homebridge server on my pi goes down?
I connected a USP Power Loss Sensor to the two terminals in an Ecolink Z-Wave Plus Door/Window contact sensor then setup a rule to tell me when the state changes. Of course my network equipment and Hubitat hub are on UPS.
Or there's this for a fraction of the price.
Wow, I should go into business selling a $1 wall wart and a $1 spdt relay for $42 and call it a UPS power loss detector. LOL.
My Freenas server connected to the UPS which everything else including HE is connected to sends me an email notification that UPS is on battery.
I’m still using this...
But now it’s on HE not smartthings
Cool stuff
Check out his thread. There are a few options in there that use the contact sensor as the reporting device. The last post is my current setup which has worked reliably and instantly for me since I set this up.
Hi @Cobra,
Sorry to bring up an old thread, what you have created here is a great little thing and was wondering if you wrote any guides on how you created this and got it running with smart things\HE?
I am interested in doing similar as I have regular power cuts, I have a UPS running and would be good to be notified when the power goes out.
For the hardware, you can make something like I posted in the SmartThings forum or you can use a Ring Extender:
I use this with an app I created “Power Off Shutdown” which you can find on my website:
Https://cobra-apps.co.uk
Or you can use rule machine
I have signed up to your site, I am happy to make what you made as it looks a lot cheaper to make that than buy the ring extender, I also have a spare Zwave water leak sensor that I could probably use with it to help build it.
I was just wondering if you had a parts list and wiring diagram on the item you made on the smart things forum, I am quite handy with a soldering iron and probably just need to order the 5v relay, circuit board & charger.
I have a Ring Repeater that sends an alert to my hub if it senses a power outage. It works great!
