Hi,
What causes the Zigbee radio to constantly reboot? Running a C8 with the most updated software. 2.3.6.146
Hi,
Heat is traditionally the first answer for this question. That might be room temperature heat, blocking of the vent hole heat, or a large load that over heats the Radio chip.
I have 6 hubs powered right now and they are all reporting cpu temps of between 35 C and 46 C (:= 96F to 115F)
Is this a new/recent issue, or have you been having it since owning the hub?
How old is this hub?
This was a new hub when the C8 was originally released. It appears that it has been happening since I have received it.
Thanks for the information. Where do I check hub temps? This sits in a well-ventilated room with A/C. The current room temp is 68. The C7 never had these issues located in the same location.
This is a great question but the answer is not always straightforward. There could be any number of things that might force the radio to go offline.
Here are some of the reasons we have seen in the past:
Here are some tips that may help eliminate or at least narrow down the root cause:
Thank you for the support information. The only other issue it could be is Wi-Fi interference. I will take a look around and see what channel everyone is switching to.
That greatly depends on your local environment and the Wi-Fi networks present within your location.
Understood. Would running a scan on the Zigbee channels be beneficial to avoid conflict?
If you are Android user, there are a few good network screening apps available on Google Play. The one I use is called: Net Analyzer Pro
Another is Wi-Fi Man by Unifi, which is also nice.
[EDIT] Oops, just noticed Bobby had already linked to info on the Wi-Fi/Zigbee coexistence...
Here's more infon on the Wi-Fi/Zigbee potential to bump into each other. And this is both your and your neighbors' Wi-Fi channels if they are close enough...
This topic has been marked solved by the community and subsequently closed. If the issue persists, or for further discussion on this topic, feel free to create a new thread to update us on your continued efforts to stabilize the Zigbee radio.
If you are logged in, keep us posted by creating a new thread >> click [HERE] to continue. <<
