What causes database to get "full"?
I got a message indicating the database was nearly full and that I need to do a back up, soft reset, and restore.
What causes this? Will it happen again?
I haven't added any devices or done driver/application updates in months.
Will app/device driver logging cause the database resource to be exhausted? If so, is there a way I can automatically purge the logs on a periodic basis?
Or, more generally, what can be done to prevent this from happening again?
What exactly is the message?
If you PM me your hub's id I can take a closer look at the hub in the support tool.
I don't recall the exact message--it was a warning that the database only had space for X records and that I should do a soft reset (which I did).
Sent you the Hub UID.
That should no longer happen with 2.2.9 - I see the hub just got updated to the latest version today.
