Hello.
I've switched from SmartThings to Hubitat and I'm experiencing significant issues with slowness and unresponsiveness. Sometimes, it loses connectivity with all devices, and none of them respond. A full shutdown for 5 minutes resolves this temporarily, but the problems resurface the next day or week. It's consistently slow, with actions taking a long time to occur, or sometimes not happening at all when turning devices on or off.
Feeling quite frustrated, I began to suspect that there might be an issue with the C7 Hub itself. Consequently, I purchased a new C8 from the USA and received it yesterday. The migration process seemed smooth, even though things worked well yesterday (as they often do after a restart), the issues have returned today. The hub fails to receive updates from sensors, and things just stop working. Now, I'm at a loss for what to do next. What could be the problem?
Additional Information:
Today, if i run Z-wave repair, about 50% of the devices are not repaired successfully (very mixed results)
I have approx. 50 Z-wave devices of the following types:
- Heatit Z-water (several child switches)
- Aeotec Multisensor 6
- Aeon Siren
- Aeon Repeater
- Heatit-Z DIM
- Fibaro Dimmer
- Fibaro Switch
- Installed Apps:
I have installed these apps:
- Action Tiles
- Advanced vThermostat Manager
- Basic Rules
- Groups and Scenes
- Hubitat Package Manager
- IFTTT Integration
- Room Lighting
- Rule Machine
About the migration from Smartthings to Hubitat:
This is what I did:
- Excluded devices from SmartThings.
- Factory reset the device after excluding it from SmartThings.
- Paired the device with Hubitat.
Some devices didn't exclude successfully from SmartThings, and some didn't pair successfully with Hubitat on the first try. Consequently, I ended up with some ghost devices after migration. As these couldn't be removed via Hubitat's web GUI and didn't disappear on their own, I removed them with a USB Z-stick and Simplicity Studio from my PC a few weeks ago. I don't have any ghost devices now.
The SmartThings hub is still active with 2 Z-wave devices and other devices using protocols other than Z-wave (e.g., TV and washing machine). There are two Z-wave devices left because one couldn't be paired with Hubitat (possibly working now), and I can't find the other one physically
I'm now desperate for a solution. Switching to a hub from another brand is not preferable, as Hubitat supports Z-water (temperature control), and it would take me two weeks to move all devices to a new hub.
I would greatly appreciate any insights that could lead to a solution.
Right now the topology looks like this, but normaly the blue dots are more distributed.
Dont know if this is telling you anything, no devices are using battery:
