In rule machine, it only says open and close
We need a little more information. What device driver are you using? What button are you using? If the driver reports the state of your curtain (open or closed), then a simple "if" statement would either open or close your curtain based on current state.
You could use button controller and the conditional action option @Pantheon suggested, checking the current state of the curtain and doing the opposite command,
Or a very simple "toggle" command that would either open or close based on current state. That is if you only want fully open or fully closed.
If (curtain is open) {
Close curtain
} else {
Open curtain
There is no toggle command I can find
I was not sure about a toggle command. Then @lairdknox 's code is my choice.
It exists for switches. Maybe not showing because of the device type. The IF > Else option shown should do the trick if you cannot choose Toggle Switch.
It’s not but thx for the alternatives
