There are two power-related events being created when a message comes in, one for daily energy and one for instaneous power. That happens near the bottom of the driver source.
What is it reporting for power now, and what does the WeMo app say it should be? Unfortunately the message format isn’t well documented, and I don’t have an Insight switch, so I’m piecing together information from various open source drivers.
Original was 30 which turns out to poll every 30 minutes. At least with the Insight you need more polling for energy state so I placed this as 3 so I wouldn’t have to make a RM to refresh every 3 min.
6- Paste it in Hubitat in, Apps Code, New App, Save
7- In Hubitat, Apps, click Add User App
8- Select the WeMo Connect App
9- WAITWAIT It can take 50 secondes or more for all your device to show. The 0 found will change…
10- Now you need to be fast to select the device you want to add and hit Done. Auto-Refresh every 30 secondes
11- Your Wemo device must now be visible in the Devices menu
You can now use Hubitat or the Wemo App to control your device. Working since Hubitat V2.0.0.104 and always working in 2.3.0.124
I wanted to share with you what i just did.
FYI that I made sure all my WEMO devices had permanent IP addresses in my router table so that the need to rediscover will be limited. I did this when I first found many issues on ST that were related to ghost WEMOs and incorrect IPs.
Ah, I see what happened there. I just pushed an update to the app that increases the refresh time for the device selector to 30 seconds (it was initially set to refresh every 5 seconds).
@lehighkid, you mentioned that you had some success with getting your Wemo Maker to work. Which app and drivers were you using? I'm trying to get my Maker working using the code posted by @jason0x43 but it doesn't seem to be discovering my Maker.
I just installed @jason0x43's Wemo and it works great except it doesn't recognize my Wemo dimmer. I noticed a post from @lehighkid last year about a version of the app that did.
Should I install @lehighkid's app too?
Is there a chance the ability to work the Wemo dimmer will be added to @jason0x43's?
On a side note, how do I know when Discovery is done?
TIA,
Jim
I have installed the drivers, and the app, but neither one can be found. I actually let the discovery run for over an hour.
I have rebooted the hub, and tried again, but no joy.
Any idea what else I can try?
Try opening the Hubitat logs, then open the WeMo Connect app in a new tab. What does the log show from the app? Also, are the Hubitat and the WeMo devices on the same subnet?
HE and Wemo devices are on the same subnet, and all have fixed ip addresses.
Here is a screen shot of log. This just keeps repeating over and over. I gave up after about 1.5 hours.
