Using a WEMO Maker with the driver provided by jason0x43 (thank-you for the WEMO drivers, by the way), I have inadvertently put my WEMO Maker into the momentary switch mode. Through trial and error and looking at the events log, I think the command sequence of On-Off-On-Off puts it into momentary contact switch mode, but I can't seem to find a command sequence to get back into toggle switch mode. I took a quick glance at the driver code, but that didn't help, either.
