Pretty basic question, and I know that the README file on jason0x43 github repo says to install all of the drivers, but before doing that I thought I'd ask if one of the drivers supports Wemo mini outlet smart plugs as I don't see that referenced specifically in the documentation?
The "smart plug mini" is the larger, older plug and it gets recognized without issue using the 02-02-2021 app code and the mid-jan drivers.
For me, the smaller "smart plug" needed to be manually added using IP and Port and gets identified as a Wemo Switch. Some playing around with the port was required. I got mine to work on 49152 instead of the 49153 and 49154 ports for my other Wemos.
So, yes, they work, but probably still needs a driver/app update.
