Weird problem trying to do a local backup
Not sure what's up .. C-8 on : 2.3.7.146
I seem to be getting a weird problem trying to do a local backup.
When I try to do a local and it downloads I get a htm file not the manual.lzf
backupDB_fileName=latest (5).htm < inside it says : backup file not found
Seems to happen a lot to me .. does not seem to matter if I use chrome or Opera
Any Idea Why this is happening ?
Can you PM me the hub id? I'll check out the engineering logs on the hub, maybe there are some clues there.
