Hi,
Since openweathermap 2.5 will be shut down soon and I was using it to get costom coords data inside webcore, I would like to request some feature like the possibility to use costom coords (keep the actual one but add another weather api with custom coords). So we could have data from the home location but also from the actual location while moving. While I m there, maybe something more friendly to use, for now we must use $weather.something.something with the right formula but it could be cool to be able to have a kind of variable to be set according to a drop down menu. Like, adding a variable and assign it last hour rain or something like this from drop down, so we could have all we need directly.
Thanks again!
@user3930 You could use Wunderground driver and simply use weatherstations close to where you want to monitor. Wunderground will show what registered weatherstations are where. You can install multiple instances.
yes, I use meteomatics and weather.com as api but some api supply some data that some others dont and I would like to supply coords (42.1245,-70.3456) and get the data for the location. I have the coordinates updating well but use it to get the data is other thing. I ll continue to check if I can match the desired data from my other api...
So you will get pretty close long/lat just by inputting one of the weatherstations close to the address you want
I ll take a look at this new one. The biggest problem I have to get all the data I need is that the data for the location I want is accurate. Sometimes it gives the closest place that is too far away. The other thing is the data itself, sometimes I need the last 24h rain for example and not all api supply this kind of data so I need to check if they supply the right data.
Thanks!
I m I the only that the webcore storage gives error? It looks like the end of the onecall 2.5 could be related but I was already set on the 3.0
