Hey gang
Got WebCoRE up and running last night, created my first Piston this morning, tested and it works fine.
Selected the External URL link
and received this error No error in the log for the Piston
The Piston code was not originally oauth enabled, I did enable it but still get the same error The 3 other pieces of code do have oauth enabled
Thoughts? Rick
The external url provided by webcore in Hubitat are not correct. I believe they are in ST format still. I had to rebuild the URl slightly to make it work in Hubitat.
I was wondering if RM would be able to expose a rule in the same way.
