Hoping someone can help... After migrating from ST, I've always had an issue with Push Notifications... it simply doesn't work for me on HE ;
(1) Using webcore, i dont see the notification anywhere and i HAVE setup my cell phone in the webcore setup page, Have used "send device notification" and "send push notification"...
(2) In my HE app - under Tools/Notification - i receive an error ....DeviceXXXX not registered to my email address"
Can some one point me in the right direction.. I truly dont know where to look next..
You should test the notification devices are working
This can be done by
HE console -> devices -> select the notification device, and issue a notify command there to see that the basic notification is working. webcore calls these same commands.
Good lord that worked...... thank you !!...... I feel silly.... akin to "reboot" - should have known..
Thanks .. when i logged out and logged back in, it asked for me choose my mobile.. when I did , I could then see my Notifications..... Thank you !!!!
So is the "Notifications" section on the App, the only place to see notifications that webcore sends ? i.e. I have a number of my Webcore Pistons doing a "send push notification.."
you should get a push notification on the mobile device in addition to the notifications section within the app.
try sending yourself another test from webcore. if it still does not work, reboot your hub
