Is there a way in webcore to access the HSM Intrusion Delay triggers?
I can find intrusion Arming and such, but not the delay version.
Also l want to have my system do something when a door is unlocked by a specific user, how can I access that part, I can in rule machine but not webcore
one last question how are you doing the any of, I have tried a few options and it does not seem to work, I can only use one. Can you send a screenshot of you editing it?
The above I was showing works, but if I try "is any of" then it does not work with 2 peoples names, That is why I was hoping to see how you have yours created, (the edit details ) are you using a Value, Variable, Expression, Argument and then what syntax are you using?
