I run webCoRE for 98% of all automatons. I am curious, does your automatons make heavy use of variables? For me I make http get calls to a LAN server running a weather station and populate about dozen variables, mostly numbers but some string. I also make a fair amount of math calculations with variables too,
I have rule machine loaded but not using it for anything. (Just uninstalled it yesterday as a test) The only other native app is for running the dashboard. All other native apps have been uninstalled or disabled.
I must reboot my hub every three days otherwise it noticeably starts slowing down on day four and slows to a crawl on day six.
The hub slowdowns are happening to a lot of people including those that have never installed webCoRE so I know it isn't the cause, but I am hypothesizing that maybe it is the repeated use of variable space that is filling up memory and gets purged when a reboot occurs. In other words, is it a problem in the groovy language itself that is the root cause.
I can create a new piston, editing ... all piston ran good. When done, I log out, then log in , still get the Error.
How to fix the Error " ... invalid token " ?
( v0.3..1009 HE: ...20200210_HE )
Thanks.
Personally I think it's global variables, RM4.0 or webCoRE, that causes issues.
I'm pretty sure there something about this on ST when I was using the ST hub but it was so long ago I cannot remember.
I've just loaded the latest update, 2.2.0.129, and webCoRE is now trashed for me on both my hubs.
A restore to the previous backup is still failing. Will try the old firmware.
Thought I'd let you all now in case you experience the same.
@nh.schottfam
Also, when on .129, if you try and update the webCoRE app by doing an import of the code, when you save it gives this.
Again in the logs, no errors.
PS I have one hub at the latest build and one at the old build so can do any testing if you need it.
