I’ve just upgraded HE to 2.3.9.158 which stated faster compile times.
Now WC has successfully upgraded through HPM. It still took quite a while, but hopefully this is now fixed.
Success! I updated to 2.3.159 and then upgraded webCoRE through HPM to the latest. From the logs, it looks like it took about 2 1/2 minutes start to finish. I am now on a C8 Pro hub, which probably helped as well.
Error Occurred During Installation
An error occurred while installing the package: Failed to upgrade app https://raw.githubusercontent.com/imnotbob/webCoRE/hubitat-
patches/smartapps/ady624/webcore-piston.src/webcore-piston.groovy.
Be sure the package is not in use with devices.
I have a different issue on my C8 hub which I believe is related to updating webCore. The hub is at my holiday home and I don't do updates if I'm not here. Early this morning I did an update via Package Manager, which failed. After that, it seems as if webCore has lost connection with devices. Pistons don't control devices and are not triggered by devices. Time Scheduled pistons run, but don't do anything as far as device control is concerned.
I have tried the following:
Manually updated the apps by importing the code.
Repaired the webCore installation with Package Manager.
Again ran an update of webCore in Package Manager - reported all apps are up to date
Rebooted the hub many times, even unplugging power during one reboot.
Refreshed devices by going into webCore Settings as if I want to select a device.
Did the last-mentioned again and added two devices.
Other information that might be relevant:
I can open pistons and make changes to them in webCore
webCoRe is not paused or disabled
webCoRe reports the following under the Engine block - Cast iron heading:
v0.3.114.20220203 HE: v0.3.114.20240115_HE - June 24, 2024.
None of the above made a difference and webCore fails to respond to any changes in the state of devices.
Any suggestions would be appreciated as it will save my holiday if I can resolve this issue.
Thank you.
Edit:
I've just noticed the following error messages in the hub's log:
And the following error regarding one of the pistons: dev:1632024-07-17 11:16:15.044warnCall to on failed: status code: 500, reason phrase: Internal Server Error
Error regarding different piston: app:1002024-07-17 11:14:56.852warnmethod curPState of child app Illuminance: Turn Night-time State Off (Sufficient Light) ran for 190,367ms
Yet another one: app:1162024-07-17 10:53:13.273debug ║ Device missing from piston. Loading all from parent (155ms)
(If I opten the piston with this error, the devices are listed and nothing seems to be wrong with the piston.)
I hope that will help to diagnose the problem. Thanks.
Thanks for your input.
WebCore has been running without issues or changes to the pistons for nearly a year. There were no issues before I updated it via HPM, so something must have gone wrong during the update.
The system, fortunately, made a scheduled backup about 3 hours before I did the update yesterday morning. I realised that after posting and decided to rather restore the update than try to troubleshoot the issue, as I'll only be at this property for a few days. Luckily, the backup was restored fine, and all is well.
Due to the aforesaid limited time, I'll try the update next time I'm down here.
Thanks again for your interest.
How would I determine an EOF when reading a string file? I can parse newlines and load data into an arrary. I just need to know how to terminate my parsing loop.
Having a puzzling issue... I have my sump pump on a GFI. To detect if the GFI trips, I put a zigbee outlet with the goal of detecting if the zigbee outlet lost power.
I setup a webcore piston that part of it checks that the health of the zigbee outlet is online (see below). I hear the message that the sump pump is dead indicating that the outlet went offline...but whenever I look at the health under the device it looks online. I then created a simple webcore piston to detect when the health changes and speak and it never does... how can that be?
Thanks for the quick response... can you explain a little more? I see the attribute in the device and in webcore... in the device it says online and when I unplugged it, it eventually went offline
I have the same check in my setup. I had to put a wait period in, i.e. offline for 4 min. I also did a "refresh" and checked for it being offline again, before flagging it for attention. It seems there are times the hub gets so busy, it doesn't go out & check device status until the load eases up.
Thanks for that idea .... i will look into that... what I still don't understand is
how can the device say online, the orig piston say its offline and the checker piston never detect a change?
