If this has been covered, please forgive.....
I am trying to flash a light switch using webcore. When the piston executes, I receive the following error in the logs:
Error executing virtual command [Light - Hallway].flash: (9ms) groovy.lang.MissingMethodException: No signature of method: user_app_ady624_webCoRE_Piston_69.executePhysicalCommand() is applicable for argument types: (java.util.LinkedHashMap, com.hubitat.app.DeviceWrapper, java.lang.String, java.util.ArrayList, java.lang.Long, java.lang.String, java.lang.Boolean) values: [[id::4c473393870a586a7b7ea7f3691709ac:, logging:3, svLabel:null, ...], ...]
I am able to use the Flash button in the device itself without issue.
Has anyone come across this? If so, a code fix?
I am running the current versions of hubitat & webcore as of 2/24/20.
Thanks,
Chris
