Receiving unusually log warnings, the log is not specific to any piston, associated with the base webcore instance. Below are a couple examples but there are about 30 of them at the same time.
app:132022-12-16 11:22:18.585 AMwarnStrange command SystemDisarm with commands [n:SystemDisarm, p:[null], cm:true] has nulls
app:132022-12-16 11:22:18.583 AMwarnStrange command SystemArm with commands [n:SystemArm, p:[null], cm:true] has nulls
app:132022-12-16 11:22:18.442 AMwarnStrange command toggleSoundMode with commands [n:toggleSoundMode, p:[null], cm:true] has nulls
app:132022-12-16 11:22:18.439 AMwarnStrange command togglePictureMode with commands [n:togglePictureMode, p:[null], cm:true] has nulls
app:132022-12-16 11:22:18.364 AMwarnStrange command toggleSoundMode with commands [n:toggleSoundMode, p:[null], cm:true] has nulls
app:132022-12-16 11:22:18.361 AMwarnStrange command togglePictureMode with commands [n:togglePictureMode, p:[null], cm:true] has nulls
app:132022-12-16 11:22:17.466 AMwarnStrange command inactive with commands [n:inactive, p:[null], cm:true] has nulls
app:132022-12-16 11:22:17.463 AMwarnStrange command active with commands [n:active, p:[null], cm:true] has nulls
app:132022-12-16 11:22:17.460 AMwarnStrange command SystemDisarm with commands [n:SystemDisarm, p:[null], cm:true] has nulls
app:132022-12-16 11:22:17.458 AMwarnStrange command SystemArm with commands [n:SystemArm, p:[null], cm:true] has nulls
app:132022-12-16 11:22:17.419 AMwarnStrange command SystemDisarm with commands [n:SystemDisarm, p:[null], cm:true] has nulls
app:132022-12-16 11:22:17.416 AMwarnStrange command SystemArm with commands [n:SystemArm, p:[null], cm:true] has nulls
app:132022-12-16 11:22:17.414 AMwarnStrange command MotionDetectionEnable with commands [n:MotionDetectionEnable, p:[null], cm:true] has nulls
app:132022-12-16 11:22:17.411 AMwarnStrange command MotionDetectionDisable with commands [n:MotionDetectionDisable, p:[null], cm:true] has nulls
app:132022-12-16 11:22:15.552 AMwarnStrange command SystemDisarm with commands [n:SystemDisarm, p:[null], cm:true] has nulls
app:132022-12-16 11:22:15.548 AMwarnStrange command SystemArm with commands [n:SystemArm, p:[null], cm:true] has nulls
app:132022-12-16 11:22:15.395 AMwarnStrange command toggleSoundMode with commands [n:toggleSoundMode, p:[null], cm:true] has nulls
app:132022-12-16 11:22:15.392 AMwarnStrange command togglePictureMode with commands [n:togglePictureMode, p:[null], cm:true] has nulls
app:132022-12-16 11:22:15.308 AMwarnStrange command toggleSoundMode with commands [n:toggleSoundMode, p:[null], cm:true] has nulls
app:132022-12-16 11:22:15.305 AMwarnStrange command togglePictureMode with commands [n:togglePictureMode, p:[null], cm:true] has nulls
app:132022-12-16 11:22:14.317 AMwarnStrange command inactive with commands [n:inactive, p:[null], cm:true] has nulls
app:132022-12-16 11:22:14.314 AMwarnStrange command active with commands [n:active, p:[null], cm:true] has nulls
app:132022-12-16 11:22:14.312 AMwarnStrange command SystemDisarm with commands [n:SystemDisarm, p:[null], cm:true] has nulls
app:132022-12-16 11:22:14.309 AMwarnStrange command SystemArm with commands [n:SystemArm, p:[null], cm:true] has nulls
app:132022-12-16 11:22:14.257 AMwarnStrange command SystemDisarm with commands [n:SystemDisarm, p:[null], cm:true] has nulls
app:132022-12-16 11:22:14.254 AMwarnStrange command SystemArm with commands [n:SystemArm, p:[null], cm:true] has nulls
app:132022-12-16 11:22:14.251 AMwarnStrange command MotionDetectionEnable with commands [n:MotionDetectionEnable, p:[null], cm:true] has nulls
app:132022-12-16 11:22:14.249 AMwarnStrange command MotionDetectionDisable with commands [n:MotionDetectionDisable, p:[null], cm:true] has nulls
Started appearing after update to 2.3.4.120.
Doesn't seem to be interfering with any particular piston.
