Hi,
I have a piston that, to keep it simple, detect the battery drop on my wife cell phone and if under 10% it set a global variable to a string.
This global trig an alexa routine that speak this string (your battery is low…)
I would like to delay it after certain time, like if after 10 pm wait until 8 am to set the variable…
Any idea on that?
Thanks!
There are many ways to do this. You might try an "Only when" condition and put in your 10pm to 8 am time restrictions. You have to check the "Show restrictions" option in your piston options to see the "Only when".
I would suggest reading through this Only When discussion and using Restrictions.
You could instead use a Time is between condition.
Yes but I want to keep the action, just report it later! Condition would just not do it if outside the range
Maybe a green shot of your piston would help here.
Something like this maybe.
Yes I think it could make it, I was looking for integrated delay but seems not to exist in this action! It’s just a turn on motion sensor for Alexa…
I ll test and see!
