Created test piston, edit and add variable.
Create a set variable expression.
At first it says invalid. I save the expression and re-edit and now it evaluates to 0.
Save the piston with the new var and re-edit and now it evaluates properly.
So it looks like new vars have to be saved first before the piston has access to them for evaluation.
app:122024-02-12 09:48:39.373tracebroadcastPistonList sent
app:122024-02-12 09:48:29.542traceEvaluating expression (264ms)
app:122024-02-12 09:48:29.196debugDashboard: Request received to evaluate an expression
app:122024-02-12 09:48:23.074debugDashboard: Request received to get piston :aa5259e1c785c1ae404c8d42264ef9ad: Rec Room Heater Test (Paused)
app:122024-02-12 09:48:18.790debugDashboard: Request received to get piston :aa5259e1c785c1ae404c8d42264ef9ad: Rec Room Heater Test
app:122024-02-12 09:48:18.260debugDashboard: Request received to set_save
app:122024-02-12 09:48:18.205debugDashboard: Request received to set a piston (chunked end)
app:122024-02-12 09:48:17.855debugDashboard: Request received to set a piston chunk (#2/2)
app:122024-02-12 09:48:17.545debugDashboard: Request received to set a piston chunk (#1/2)
app:122024-02-12 09:48:17.280debugDashboard: Request received to set a piston (chunked start)
app:122024-02-12 09:46:14.476traceEvaluating expression (283ms)
app:16422024-02-12 09:46:14.470error ║ get Variable decRecRoomOffset [name:decRecRoomOffset, index:null] decRecRoomOffset not found
app:122024-02-12 09:46:14.153debugDashboard: Request received to evaluate an expression
app:122024-02-12 09:45:25.248traceEvaluating expression (258ms)
app:122024-02-12 09:45:24.950debugDashboard: Request received to evaluate an expression
app:122024-02-12 09:45:06.150traceEvaluating expression (398ms)
app:122024-02-12 09:45:05.625debugDashboard: Request received to evaluate an expression
app:122024-02-12 09:44:19.256traceEvaluating expression (284ms)
app:122024-02-12 09:44:18.929debugDashboard: Request received to evaluate an expression
app:122024-02-12 09:44:04.904traceEvaluating expression (308ms)
app:122024-02-12 09:44:04.556debugDashboard: Request received to evaluate an expression
app:122024-02-12 09:42:28.865debugDashboard: Request received to get piston :aa5259e1c785c1ae404c8d42264ef9ad: Rec Room Heater Test (Paused)
app:122024-02-12 09:42:07.858debugDashboard: Received set piston logging level
