I am new to Hubitat and have not seen this option: When creating a Dashboard you can nicely configure it they way you want. However, you can only specify the width and height of a tile. I use the Dashboard on a number of different devices and was wondering if it would be possible to add a feature to add a feature of specifying a minimum width and height. that way, when you use the Dashboard on a laptop, it will resize based on your screen size, but when I use it on a smaller device the tiles will only reduce to the size specified and no smaller.
Thanks, i did do that as my co-worker uses Hubitat as well. However, it doesn't seem to render cleanly. Meaning, the tiles don't appear uniform and there is overlap between of text and image at times. However, I am sure it is something I am doing... Thanks
So - Zarthan, wanted to thank you for the response. I Looked into my Dashboard and realized I had a few extra rows and columns which seems to have caused the issue I was experiencing. I removed those and all looks good.
thanks for the quick response
