Hello. Some time ago I wrote this post about GUI glitch when pointing by mouse on any button:
We have now 2.4.0.144 with new GUI but this bug is still there. Why developers didn't fixed or found it? Is it possible that there is any setting ?
As was noted then
I know but it happened all of the time, shouldn't it be fixed by developers? I think this forum is only way to contact them...
It’s a CSS issue that can litterally be made to happen with every button on a web interface that uses any type of animation on the button if you try hard enough.
IMHO there are MUCH more important things to be worrying about.
I have seen the relevant developer acknowledge this problem, which is apparently tricky to pinpoint a fix for in the current UI framework but also pretty easy to avoid, as noted above, and shouldn't cause any problems. It will likely be looked at as the UI contiues to evolve (you may have noticed significant changes in 2.4.0). Are you experiencing any functional problems as a result that need addressing?
