Weather driver
Hi,
I am trying to find a weather driver to use with Weather tile.
installed "Weatherstack Weather Driver" from:
created a device using a working API key.
but the tile does not get update.
I enabled debug for the driver, and I can see that it gets data from weatherstack.com:
dev:2642021-03-14 17:24:16.410 debug>>>>> api: returned - [request:[type:LatLon, query:Lat 40.97 and Lon 29.10, language:en, unit:m], location:[name:Goztepe, country:Turkey, region:Istanbul, lat:40.967, lon:29.100, timezone_id:Europe/Istanbul, localtime:2021-03-14 17:24, localtime_epoch:1615742640, utc_offset:3.0], current:[observation_time:02:24 PM, temperature:17, weather_code:113, weather_icons:[https://assets.weatherstack.com/images/wsymbols01_png_64/wsymbol_0001_sunny.png], weather_descriptions:[Sunny], wind_speed:13, wind_degree:240, wind_dir:WSW, pressure:1012, precip:0, humidity:36, cloudcover:0, feelslike:17, uv_index:5, visibility:10, is_day:yes]]
dev:2642021-03-14 17:24:16.393 debug[request:[type:LatLon, query:Lat 40.97 and Lon 29.10, language:en, unit:m], location:[name:Goztepe, country:Turkey, region:Istanbul, lat:40.967, lon:29.100, timezone_id:Europe/Istanbul, localtime:2021-03-14 17:24, localtime_epoch:1615742640, utc_offset:3.0], current:[observation_time:02:24 PM, temperature:17, weather_code:113, weather_icons:[https://assets.weatherstack.com/images/wsymbols01_png_64/wsymbol_0001_sunny.png], weather_descriptions:[Sunny], wind_speed:13, wind_degree:240, wind_dir:WSW, pressure:1012, precip:0, humidity:36, cloudcover:0, feelslike:17, uv_index:5, visibility:10, is_day:yes]]
what am I missing ?
is there a better driver that I can use ?
I've had great luck with...
+1 on the OpenWeatherMap recommendation.
thanks.
I checked my old apps for Smartthings hub. They mostly used a built-in command "getTwcForecast()"
is there such built-in weather service for Hubitat ?
I guess no, since everybody is using 3rd party services. But in any case I just wanted to ask before starting to integrate with anything else.
