The Weather Canada driver has been updated and now uses OWM API 3.0.
You can find it in HPM.
Correct.
It’s a little confusing since you’re using a different forum account than the one you used to use when creating the driver.
Ijust installed it but I m confused about they fields to edit in the device... I can see the OWM key but what is this: EC Weather Alert RSS Feed
That would be Environment Canada Alert RSS feed.
