Weak Zigbee signal
I am getting an alert that I have weak zigbee chanel. This is first time I received this alert. Do I just change the chanel and wait a day or so? I have just migrated to C8 Pro.
Are you experiencing any Zigbee problems? It's just letting you know that you can take action if you are, as some users have had problems with your particular combination. If you're not, you can dismiss the message.
I have one Zigbee receptacle that is not working but I can turn off or on with mobile app. All the other 3 receptacles work so far. I just migrated 2 days ago to c8 pro
Read from here and below:
Here is another explanation up above in the same thread:
Hmmmm... Not sure exactly what you mean. It sounds like you can successfully control this outlet using the Hubitat Mobile App on your phone, correct? If so, then what about this outlet is not working? The Hubitat Mobile App simply communicates to your Hubitat Hub, which then communicates to the outlet via Zigbee.
