dont know when it was broken but in latest relase notice the garage door is not reporting status..
with the generic garage door opener..
it is paired s2 and has working fine until recently .. changed the battery in the tilt sensor and it beeped immediately but that is not the issue.. it can be controlled fine by the open close command but does not show a status change until i manually hit refresh.. same with opening manually.. it is only one hop from the hub see images.. there must be an issue with the driver?
Blockquote
