I feel pretty creative on this, but would like to see if there is a better way to do the below rule.
I have an Enerwave ZW-15RM-PLUS set as a Zooz Outlet in HE. My case is that I want to prevent my Well Pump from burning up if its running without Water for some reason.
When well pump isn't running, it sits at 0 Watts. When well pump is running properly, it is over 900 Watts (usually between 1000-1200watts). When it runs without water, it is usually pulling around 700 Watts.
I cant just shut off switch when i get a report of watts between 100 & 900 Watts because it ramps up from 0-1100 over about 5 seconds, so one rule would shut it down when its working properly.
I have two virtual Switches "Virtual Well Issue 1" & "Virtual Well Issue 2".
I have my first rule evaluate if the plug reports any value between 100&900 watts. If this rule is true, it will set "Virtual Well Issue 1" to On after 30 seconds.
I have my second Triggered Rule fire when "Virtual Well Issue 1" is set to On. It reruns the same rule and if its still true, it will Trigger my second virtual switch and Send notifications, ring siren and turn off Power to Well.
Anyone else have ideas for an energy tracker that will factor Watts, Time, or total energy used within a set period.
