I have a second home located in Virginia and while the winters are pretty mild, a cold snap can drop the temps to the high teens/low twenties. The house has an unconditioned crawlspace and I recently spent some quality time down there installing heat tape and pipe insulation on a 20’ run of ¾” copper water supply line that leads to the main water shutoff. The heat tape is controlled by a thermostat block (turns on at 35 degrees, off at 45 degrees) powered by an outdoor GE Z-Wave outlet. This all seems to work well enough but there’s currently no way to tell if the heat tape is actually doing anything. Failure of the heat tape or thermostat block is likely to eventually happen so I’m looking for a temp sensor with an external temp probe that I can attach to the surface of the water pipe to confirm that the heat tape is actually doing something. I have a water shutoff access panel in my front hall closet and I’m thinking of adding something like the Qubino ZMNHID3 Thermostat Module with External Temperature Sensor. The Qubino would be installed in an electrical box in the closet and the temp probe fed through a small (sealed) hole in the floor leading to the crawlspace. I’m guessing I can zip tie the probe to the outside of the water pipe and cover the probe with foam pipe insulation. Ultimately, I’d like to create an HE rule that monitors the temp probe and if temp is 32 degrees or lower turn the z-wave outlet on, monitor the temps for say 2 hours and if there isn't a rise in temp send a text alert.
The property is located 600 miles away from our primary residence and we're only down there approx. 6-8 weeks during the winter so I'm looking for something that's reliable and relatively maintenance free. Crawlspaces suck(!!!) and my goal is to limit the need to enter the crawlspace to confirm everything is working. How well does the Qubino ZMNHID3 wotk with HE and is there another device that might be better suited to the task? Are there any other options I may be overlooking?
