I use ST water sensors, and I put one under the drip pan in my furnace to detect an overflow. But sometimes a little water escapes from the coils and could cause it to trigger, and this ST sensor takes many hours to dry out…. if occasional drops keep escaping, it might continue giving wet status continuously. Others already noted it’s too low to the ground, clearance of about 2mm….also, the bottom sensing pins are too close to each other, 2-3mm apart, and I’m concerned at some point the dust will blow in between them and cause it to trigger.
What can you recommend with these features:
- raised a little higher from the ground to dry faster
- with more space between the pins
- needs to report dry with no delays once it’s in fact dry
- Needs to be a single piece compact sensor, not the one with a wire like the Utilitech (which does have bigger longer pins, but just too cumbersome to install)
thanks in advance.
(sorry it's the wrong forum...I meant to post this to Getting Started admin feel free to move )
