Hopefully my last help request...
Last piece of the puzzle after turning SmartThings off is to get my leak sensors to automatically close my main valve...
I have a basic rule that states that if any leak sensor is wet the valve must be closed. Looking at logs, the automation seems to work, but the valve doesn't close. I can close the valve from the dashboard so it's connected just fine.
Logs:
[app:66]2021-07-17 20:53:02.671 [info]act: Close valve Main Water Shut Off
2021-07-17 20:53:02.664 [info]evt: Washing Machine Leak Sensor water wet
What exactly failed? The rule ran the action to close the valve, according to your logs. If the valve did not close, odds are it's something about the valve device. Does it open/close from its device page?
Valve doesn't work with Basic rule. I posted a few weeks back below but never got a chance to look deeper since it's summer and I don't have access to my hub most of the time.
Looks like the implementation of open/close valve never was completed, only the UI portion was actually done. I will get that fixed and into the next hotfix release.
