Does anyone have a Lutron L-BDGPRO2 lying around that they would like to offload, preferably in the UK to keep shipping simple.
Let me know if so....
Marc
Marc
I would check ebay though I don't think lutron is sold much in the uk
There’s plenty of Lutron installations here, mainly Grafik Eye. I am monitoring eBay but thought I would ask here too.
Is the Pro2 bridge the only option to integrate two QSGRK-6PCE to Hubitat or can I use a RA2 Select Main Repeater?
FYI - Lutron uses 868 MHz in the UK, and a much lower frequency in the US.
So a North American smart bridge pro will not “talk” to your devices in the UK.
Here in the US, the Lutron Caseta Smartbridge Pro2 devices are only able to be paired with other "Caseta" devices. Switches/dimmers/keypads designed for Radio RA/RA2/RA3 and other higher end Lutron lighting systems will not work with a Caseta Smartbridge or Smartbridge Pro2.
Before spending any money on a Caseta Smartbridge, it might be worth a call to Lutron tech support to see what your options are.
So in the Uk, what are users using to enable as Lutron Grafik Eye QS to work with Hubitat? The documentation lists several devices so if some don’t work here it would be good to know what will. Or is nobody outside of the US using Lutron with Hubitat?
That's a Grafik Eye, I have two of those. What I am talking about is the 'middleware', per the documentation: "In order to connect your Lutron devices to your Hubitat Elevation network you will need a Lutron Smart Bridge Pro, RA2 Select Main Repeater or RA2 Main Repeater." I am also aware that RF frequencies are different in Europe to the USA, so my question is, which of the above do I need to integrate my Grafik Eye QS's into Hubitat in the UK?
You can't connect grafik eye I believe. You can connect ra2. @mike.maxwell is that correct?
