They're designed to fit in a US switchbox....so, even if they came in UK frequencies, would you be able to use them? But no, I don't believe that they do.
Just curious, what do you need that radio RA2 can offer but caseta canât?
- Dimmer "on" programmability. Caséta is 100% only. RadioRA 2 is configurable to a set level or previous level. RA2 Select is the same as Caséta. Makes little sense as much cheaper Z-Wave devices have configurable "On".
- Keypads. Better looking and more functionality than a Pico.
- Better functionality. Maestro style toggle dimmers have 4x the surface area to engage power than a Caséta on/off button. The dim bar is easier to engage than the up/down buttons. Also aesthetics.
RadioRA 2 is a premium over Caséta. But if you get a good quote from a local or on line supplier the difference is smaller than comparing MSRP. Especially if you need/want neutral wire connections and/or ELV dimmers.
Caseta handles 75 devices, Radio RA2 handles 200. Thatâs the only âlimitationâ I can think of.
