Also I see you have a script. Driver allows to make it interactive. Script child device it self is a 'switch' that allows to start/stop your script (and can be spawned as a dashboard tile).
And scipt child device has few attributes you can alter from within shelly script: (text, numeric and one generic that also can be shown on a dashboard with any custom value).
Good afternoon, I put my case in case it is worth it to someone.
The driver is really good, but that query every 1 second consumes more hub resources than I would like.
In my case I need to measure the V of a device and let me know if it goes beyond X, I use only one of the outputs to activate a device if that happens.
So after testing the driver I realized that I can leave this job to Shelly in a configuration of if the ADC input goes from x V activate the second relay and deactivate it after 3 seconds.
Through the I/O this reaches hubitat without polling anything, and by rule, if the second relay is activated, I activate the first one for x seconds.
This way I use the native shelly switch driver and don't overload the hub.
It is a particular case, I am very grateful to all the developers, but for my specific case this has been a better solution.
Hi,
I'm looking at measuring the discharge pressure of my pool pump using a dumb pressure sensor 0.5-4.5VDC. Saw the Shelly Uni Plus, and was wondering if it would work. Is there a driver available?
Thanks, John
Hi, I read that @Cobra@BobR@tomw@daniel.winks@justinrsteele previously were trying to make @tomw 's Shelly UNI driver to also report out the Temperature and Humidity of the Common Child Device from a DHT22 connected to 4/5/6 on the Shelly UNI.
I am trying to do that and see Temperature and Humidity on the webpage of the Shelly (as well as voltage on ADC, which I can show as a tile), and it reads it into the Common Child Device also, but I am not sure how to get it to display a Temp and Hum. It would be great if both Temperature as well as Humidity could be reported as Current States in the Common Child. Something I am missing? An extra sub-driver?
I can share the status string if that would help.
