Voltage reading outlet
Looking for an outlet (or other device) that can report household line voltage. Is there a product available today that does this?
this works great and works indoors or out.
Zooz Z-Wave Plus Power Switch ZEN15
I use a Zooz zen15. It is zwave. Works great. Reports line voltage as well as power consumption.
https://www.amazon.com/Z-Wave-Power-Switch-ZEN15-Humidifiers/dp/B07578W7KY/ref=asc_df_B07578W7KY/?tag=hyprod-20&linkCode=df0&hvadid=216516247812&hvpos=&hvnetw=g&hvrand=15511227300118696404&hvpone=&hvptwo=&hvqmt=&hvdev=m&hvdvcmdl=&hvlocint=&hvlocphy=1016367&hvtargid=pla-362621539881&psc=1&mcid=94689785d06f39bd9bbf2ea30ed1eadb&gclid=CjwKCAiAvJarBhA1EiwAGgZl0CnT5mP8hOZLavSApspuSa6llaXGI9yp2J6atV3G4RYidGubwuof2BoCJoYQAvD_BwE
Thanks. Anything smaller, less heavy duty. Like a typical wall outlet module?
The Aeotec Smart Switch 7 is very customizable (via z-wave parameter options) and very reliable, but it's ridiculously expensive these days. I picked a couple up years ago at a much better price, and they have been rock-stars for me.
This plug will give voltage. I can be chatty but seems to be a bit better with the firmware update available via HE.
THIRDREALITY Zigbee Smart Plug with Energy Monitoring,15A Smart Outlet, Zigbee Repeater, ETL Certified, ZigBee Hub Required,Work with Home Assistant,Compatible Echo Devices and SmartThing https://a.co/d/cTtCw10
Using the Tuya Energy Metering Plug driver
Where do you find the Tuya Energy Metering Plug driver? I couldn't find it using the Hubitat Package Manager App.
The Zooz ZEN04 plug will also do this.
Try Tuya Zigbee Metering Plug
