Is there a way to visualise my habitat zigbee network? Using additional hardware or software?
I'm trying to get a nice visualisation like I see in homeassistant / zigbeemqtt
As an aside, for those struggling with the Xiaomi sensors; a bit of a faff, but these have been rock solid under homeassistant and zigbee2mqtt - I use node red to push to hubitat. The repeaters are Ikea sockets.
I would like that to!
And for zwave aswell.
For zwave the C-7 hub has a bukt-in graph of connections, or if not in a C-7 you can pair a secondary zwave stick to the hub and use the SiLabs PC Controller software suite to see the neighbor map.
Thanks Jason, do you have a C7? That might be what drives me to upgrade. Does it should a visual representation like in my screenshot? Just Zwave or Zigbee too?
I have c4, c5 and c7.
I wouldn't upgrade for just that...
Like I said you can get literally the exact same neighbor graph with a $15 zwave dongle and the free pc software.
There is no zigbee device map in any version of the Hubitat hub. Can get a map via an xbee, though. There are a few threads on this forum about that.
The zwave map - in hubitat or the SiLabs PC controller software - looks like this:
If you check out the XBee thread here on this forum, there's a great way to visualize it using XCTU, like this:
