I have 2 of these on 2 different doors. Been working well in terms of open/close events for my use for the past 2 years or so. I am using the generic zigbee contact sensor (no temperature) driver.
I can't get any battery status out of them. They report 0. I tried the generic zigbee contact sensor with temperature but that doesn't seem to get me battery status.
Any ideas on how to get them to report battery status?
Copying this is this helps out:
Current States
battery : 0
contact : closed
State Variables
lastBattery : 1648683296
Device Details
Create Time 2020-11-23 4:48:39pm PST
Last Update Time 2022-04-12 10:05:19pm PDT
Last Activity At 2022-03-31 6:01:05am PDT
Controller Type ZGB
Data
endpointId: 01
model: E1D-G73
application: 05
manufacturer: sengled
I have a ton of these (pretty much my only contact sensor) and use the generic Zigbee contact sensor with them (and it does report temps), haven't had any issues. This is what shows in the Data section:
It's weird that the detail for a sengled sensor showed up.
You don't have a sengled sensor in the system do you?
Generic ZigBee contact sensor should work for both the Visonic and sengled. Don't forget to press configure button on the Device detail page after changing the driver.
Agree...something odd about how the devices joined, and they should report temp and battery w/the generic Zigbee contact sensor driver.
@par.botes - Remove and re-pair them...since they are Zigbee they will rejoin w/the same name and automations using them will continue to work after they re-join.
