I had this working, removed the VT, and now cannot get it back again.
I want to have a Virtual Thermostat that gets its temperature from a Fibaro sensor, but cannot figure out how to associate the temp sensor with the VT.
Could someone please lead me thru this using pictures and short words?
Well, your virtual thermostat allow you to set the level of the temp manually. So, you should be able to use a rule to set one to the other.
In the past I did this with wato. But now that RM has change as an event option, you could probably do it there.
Can you describe in a little more detail what this means?
I created an app to take the temp from a sensor and put it into the thermostat.
