Virtual thermostat asymmetric hysteresis?
Could the virtual thermostat driver be updated to support an asymmetric hysteresis setting above/below the temperature setpoint?
Or does anyone know of a published virtual thermostat driver that I could take a closer look at?
Thanks for considering, tagging @mike.maxwell, @bcopeland.
You can simulate asymmetric hysteresis by offsetting the base value so hysteresis it balanced.
For instance:
75° going up = 2, going down = 3
is the same as:
74.5 up and down hysteresis = 2.5
Now if your goal is really to really more resolution... that is a different issue.
Thanks, I have considered making some rules to shift the virtual thermostat temperature setpoint up and down slightly as a workaround. But I’m not that great at rule logic, and changing the hysteresis setting in the driver would be simpler (for me at least, not for hubitat devs :slight_smile:) .
