Hi guys
Is there an app that can help syncing the virtual switches with the realys? Since I have several dual relays switches I use Vitual Switches to handle them.
HR
Hi guys
HR
The built in mirror app may be able to do that.
@potts.mike i tried but it doesnt work for me. Dual Relays have 2 switches and they dont show in this app.
Then you can use rule machine.
Could use Simple Automations. It can even turn the switch off when the relay is off all in one rule
Do you have an example? I cannot select the switches inside the relay.
thanks
