Hi All,
I have added a WIZ RGBW Light to Hubitat. Since it is not discoverable in HomeKit, I have added a Virtual RGBW Light.
Now, I want to set all the options from HomeKit for that virtual RGBW light to pass to the Real RGBW bulb so I can easily use all settings.
Is there any easy way, or do I have to configure every attribute manually?
If MIRROR (built-in app) doesn't do it for you, this community app might serve your intended purpose, though I have not tried it with virtual RGBW devices:
* Color Coordinator
* Version 1.0.0 - 7/4/15
* By Michael Struck
* 1.0.0 - Initial release
* Licensed under the Apache License, Version 2.0 (the "License"); you may not use this file except
* in compliance with the License. You may obtain a copy of the License at:
* http://www.apache.org/licenses/LICENSE-2.0
* Unless required by applicable law or agreed to in writing, software distributed under the License is distributed
* on an "AS IS" BASIS, WITHOUT WARRANTIES OR CONDITIONS OF ANY KIND, either express or implied. See the License
* for the specific language governing permissions and limitations under the License.
* 2020 lgk port to hubitat
definition(
name: "Color Coordinator",
This file has been truncated. show original
I never know about the Built-In app. Thanks for introducing it. Also, the community app worked.
system
Closed
February 1, 2024, 11:08pm
4
