Do you have a parent app or driver on Hubitat that is manipulating the state of this virtual dimmer, then? If so, for all of these devices, you probably want to use the built-in "Generic Component..." drivers instead of the "Virtual..." drivers. They do not perform anything on their own, just generate events based on what you pass to their parse()
methods, so you will not run into this issue with a component dimmer device. The HubitatPublic repo has examples of some parent/child devices that use this pattern.
If you do need "freestanding" drivers (e.g., because you just have a rule or other app that needs truly full virtual devices to manipulate directly), then this approach will not work, as these drivers are not meant to be used on their own. Otherwise, this seems like a better idea to me.
